How to build a vocal booth?
redis
I'd like to build a vocal booth for my home studio and keen to get some advice on how.
The main constraints:
- I live in an apartment and need to get the cutting of materials done in NZ stores or elsewhere.
- I'll need to do the assembly in the room, otherwise it won't fit.
- Budget is limited to 1-2k NZD
Requirements:
- The booth is 2 meters high, the inside floor area is 1x1.1 m, the wall/floor/roof thickness is ~10cm.
- The door size is 185x70cm, ideally it shouldn't let any air in and out and should be the same thickness as the walls to ensure noise isolation
- Ideally a power socket hole is required in one of the walls, the size is 7.5x11.5cm and it's 28cm from the apartment floor
- Don't need done: ventilation, lights, windows or interior.
Questions:
- Is the wood frame necessary or it's enough to make walls out of 2 plywood sheets with insulation sheet inside, and assemble them with angle brackets?
- Which materials would you recommend, especially for insulation / for ensuring there's no movement in plywood+filler 'sandwich'?
- Any general building tips or gotcha's?
- Any ideas on where to do the cutting in the city if I don't find a store that would do it for me?
Any help is appreciated.
Re: How to build a vocal booth?
Welcome to the Bunnings Workshop community @redis and thanks for joining in the discussion. We are looking forward to seeing this project come together.
One of our resident Bunnings D.I.Y. experts in @EricL will be back on the site later today to assist you. Let me also tag experienced members @Brad@TedBear and @Remarka6le to see how they might go about this project.
Hi @redis
In order to build your vocal booth, I suggest using Tigerply 2400 x 1200 x 12mm Non-Structural Untreated Plywood in conjunction with Pinetrim 65 x 18 x 1.2m Kiln Dried Untreated Pine Dressed 4 Sides. I recommend using Zenith Chipboard CSK Head 8g x 30mm 30pk Gold Passivate Screw to join them all together.
In order to acoustically insulate the booth, I suggest using two Expol 2400 x 1200 x 25mm S Grade Polystyrene ThermaSlab on top of each plywood covered in All Set 1.8 x 2m Moving Blanket. The blanket will need to be stapled to the plywood so that they don't fall off.
I suggest having one side of the booth as the door rather than cutting a door into one of the panels. The booth can be secured by attaching handles on the opening sides of the booth.
I'm currently drawing a sketch to give you a better idea of its assembly. I'll post it here tomorrow.
Brad
Soundproofing blog
It is a long read and mentions some products that arn't available here.
Interesting to note the use of metal studs instead of wood giving a better dampening result as the metal is less ridgid to reduce vibrations. I thought wood being less flexable would dampen better but it seems I got it wrong.
Nice thought on the door being a wall.
Hello @redis
I've placed a sample sketch of the sound booth to give you an idea of how to put it together. I suggest speaking to the trade counter to find out which day is the best day to come to have your panels cut down.
Hi @Brad
The parts are from Bunnings NZ. There are equivalent panels and materials here in Australia.
