How much sanding of skirtings needed before painting?
siva26
Cultivating a Following
Hi all,
I'm trying to sand-off my current skirting and paint it to give a fresh look. I'm not able to judge how much to sand. I used a 120 grit sandblock and based on the advise the skirting is slightly dull but not too much. Would that be enough to start painting? I'm afraid the paint won't stick. Should I go for lower grit?
Also, isit the same technique to sand doors?
Attaching the pic of the sanded skirting
Re: How much sanding of skirtings needed before painting?
Hi @siva26,
My go-to product in these situations is Dulux Maximum Adhesion Primer. It's perfect for gloss or challenging to paint surfaces. Simply give the area a quick sanding with your 120-grit paper, wipe the site down and then prime. Using a specialty primer like this takes away all the guesswork.
Essentially, if you're just sanding, the gloss must be removed until the surface appears dull and doesn't reflect light easily. In your top image, you can clearly see the reflection of your flash or light source. You don't want to be able to see clearly (for paint) defined reflections.
It's hard to tell from just a picture whether your skirting is ready to be painted, but it looks like you've done a reasonable job of removing any sheen level. The door will be the same process. A good indicator is that the skirting and door should have a similar sheen to your walls when ready to paint. Walls are typically low-sheen.
siva26
Hi @MitchellMc,
Thank you so much for your advice. I think the skirtings still need some sanding but I rather go for the primer you have mentioned as I am not sure. So just to run through the steps again:
1) Just do some light sanding and wipe off the area
2) prime the area with Dulux Maximum Adhesion Primer
3) Paint the skirting with the colour I want
And the above steps can also be done on room and bathroom doors.
Is the above information correct?
 Siva
That's it, @siva26!
After sanding and prepping with the primer, you'll be using a hardwearing topcoat paint like Dulux Aquanamel for doors and trims.
siva26
After using Dulux Maximum Adhesion Primer, can I use Taubmans ultimate enamel as top coat or should I still stick to the same Dulux brand? I bought this before starting my painting.
You sure can use the Taubmans ultimate enamel over the Dulux Maximum adhesion primer, @siva25. They are both water-based and compatible.
siva26
Hi @MitchellMc ,
Thank you so much for all your advice. Really appreciate it!
Siva
It's my pleasure, @siva26! Let us know how you get on, and please shout out if you get stuck.
