Hey guys.
I'm doing a bit of copping around the pool, just some paving that have come loose. We have red brick pavers and fibreglass pool. Which adhesive would be best for it??
Nerea
Hi @nerea,
Apologies for the delayed response. Thank you for your question.
I'd suggest using Dunlop 2kg Tile-All Tile Adhesive.
When the coping tiles have been removed, make sure you clean up and remove the old adhesive, so you have a smooth surface to work with. You may need a hammer and a bolster to chip up the old stuff. Once any hard adhesive has been removed, clean the surface with soapy water and a scrubbing brush.
To ensure even coverage, apply your adhesive and spread it with a QEP 10mm Square Notch Trowel. Once the whole area has been covered with your adhesive, press the coping tile into position, making sure the notches of tile adhesive compress.
Thanks so much. I have it all ready and clean the old adhesive.
Just to note, this are not tiles...and brick pavers....still the same adhesive??
Hi @nerea,
Yes, the tile adhesive is still the product I'd suggest.
Typically, you would use mortar with bricks, but mortar does not respond well to the chlorine and salt you will find around pools.
The tile adhesive is a cement-based adhesive that is very similar to mortar but is fine for use around pools.
How about one that comes in those tubes? Just so its easy to apply as I'm no expert 😜. Cheers
Hello @nerea
Jacob's product recommendation is spot on, but if you are only doing one or two pieces then yes, you can use the Dunlop 310ml Tile-All Plus Premixed Tile Adhesive. But if you are doing quite a few pieces then it would be worth using the Dunlop 2kg Tile-All Tile Adhesive.
