Should I add a downpipe to fix overflow?
andre999
Hi all,
I have a water overflowing issue at my flat.
At the other end of the block (30m away from my flat), the water in the gutter flows down thru the downpipe straight to the storm drain. Whereas there is no downpipe from my flat's gutter. This cause an overflow of rain water.
Is it a good idea to add a new downpipe from my gutter to the nearest drain which I believe share with the kitchen and bathroom?
Thank you.
Re: Should I add a downpipe to fix overflow?
Hi @andre999,
Could you please share some photos so members can see what you are working with and share their opinion on whether the existing setup is sufficient?
Given your other water ingress issues, it also seems prudent to also recommend a plumbing professional to make assessments on-site.
Hello @andre999
If you are living in a flat with a homeowner's association, I suggest speaking to the property manager first and telling them your predicament. It's not that you can't put in a downpipe, but it has to be done to the standards of the homeowner's association or body corporate. A plumber will definitely be involved as it involves plumbing and guttering.
If you can share a few photos of the area, it will give our members a better idea of what's going on. We can then make recommendations on how to move forward.
andre999
Hi @jaso @EricL , please close this thread. I have decided to use other alternative. Thank you.
