This project is going to be made by Ladies in our RSL Village. We have just formed a Ladies Shed group We are preparing to be trained in the use of the machines and when we have obtained competency, we will be able to create kits for those who would like to put them together but not necessarily use machines. A small group want to learn to use the machines and we will cut the timber into kits.
The wood we are reclaiming from pallets. The photo shows a large version Christmas Tree, a smaller version and a tiny version. I myself want to put together a medium version to complete the set.
These are the prototypes which were cut and assembled by Tony one of our male residents. He kindly offered his help in working out angles, cutting and assembly. This is special because it has reinvigorated Tony's love for woodwork as he was a master carpenter in his day. He had to give it up whilst nursing his wife until she passed. Tony is nearly 88.
2 pallets with HT certification
Disassembled and nails removed.
Tony did not use the machines in the shed and worked in his own garage using:-
Bosch Jig Saw
Makita Battery Drill
Ryobi Sander.
various hand tools hammer, etc.
Glue PVC
Nails and Screws
FPallett Christmas Tree Pattern Large Size
The Angles were calculated from this pattern and templates were made. So that simplified the cutting of the boards which were cut together so one could be flipped.
These cut boards were, placed on a backing plank and screwed, glued and nailed. This plank was allowed to protrude at the end by about 6-8 inches so that the feet could be attached.
The feet are of a H design and the tree is fixed permanently. In th4e next prototype we would like to design so that it is removable. for easier storage. The feet were designed by Tony so I can't really describe how they were done.
The were finally sanded to removed splinters. They can be painted or varnished. Also, will allow for signage to be stenciled onto the branches with a Christmas theme.
The pattern was a free pattern thanks to Tool Belton You Tube
Nice project to help build woodworking skills @Marianne2. Many thanks for sharing.
We have loads of community members who are passionate about recycling pallet timber and you'll get inspiration from all the amazing projects shared on this site. Check out our Top 10 most popular pallet timber projects for starters.
Welcome to the Bunnings Workshop community. We look forward to seeing what you tackle next.
I'm in the process of making a pallet Christmas Tree. The idea is from the net.
Rain isn't helping - however, I have noticed wet/soaked pallets come apart a lot easier without the wood splintering.
Hi @Noyade,
This seems like the perfect festive woodworking project to put some reclaimed pallet timber to use.
I'm excited to see your results.
Thanks @JacobZ
I started off small with this wood scrap tree...
Also working on a 'Pallet Santa'.
I'll keep you posted. 👍
Cheers!
Getting there....
It's beginning to look a lot like Christmas 🎶 🎄
Looks almost ready for paint and decorations.
Thanks for the update @Noyade, I look forward to the next one.
Thanks @JacobZ
Rain and the humidity has set be back - but gonna deliver it to my wife's workplace today.
I'll probably get my snowman finished later today - if it's not too hot.
Cheers.
Now positioned at her place of work...
Frosty now has arms...
