Hi guys,
I have just purchased a Ozito HPW 2030 and for the life of me I cannot get it the pressure to work. I have read the other Q&A’s and troubleshooted from that, including purchasing a connector hose.
The motor just wants to suck the air and not spit any out, makes an awful sound on top of the motor nose. I have;
plugged and unplugged everything
tried different hoses
left the water to rub before turning on the pressure hose
not sure what else it could be?
I am replacing an old karcher,
Hi @Lynne3,
I'm sorry to hear you are having trouble with your Ozito pressure cleaner.
The only thing I can suggest that may help is to increase the pressure of water coming from your hose to the pressure washer. Pressure washers require a consistent and adequate water supply to operate efficiently. If the water flow is too low, the pressure washer may not generate enough pressure, leading to weak cleaning performance or the pump running dry, which can damage the machine.
If this does not fix the problem, I would suggest returning the machine and asking for a replacement. As it has only just been purchased, there will be no issues with swapping it out.
Hi Jacob,
Thank you for your advice, you were right, went to my local Bunnings swapped it over for a replacement, I am having the same issue so I think it’s a water pressure issue which is odd as the Karcher was ok. I will have to pop back and return the unit which is disappointing as it is a great compact unit with great reviews.
Thanks again.
Hi @Lynne3,
I find it odd that your Karcher would work, but your new Ozito washer wouldn't, especially considering you've tried two different ones.
Did you have a photo of the tap that you could upload? If you use the tap without the pressure washer connected is the flow rate really low?
If this is the case it might indicate an issue, you'd need to contact a plumber for assistance with.
Let me know what you think.
Hi Jacob,
I appreciate your commitment to this! It turns out the Ozito needs more water pressure than the old karcher. I ended up returning the Oztio.
The karcher I think is a 520m - super old. With a shorter hose on the karcher it’s performing better. I live in an apartment building, I notice a difference in water pressure when using the karcher between the front and back balconies, even on a short hose.
Thanks Jacob for your help! I’ve learnt a lot in the past few weeks.
Shout out to the team at Bunnings Moorabbin for their customer service.
Thanks for the feedback @Lynne3. I'll be sure to pass on your regards to the team at Bunnings Moorabbin.
