Mobile herb and vegie trolley using pallets
JoeAzza
I haven't had a vegie/herb garden for a long time. I just missed having having fresh herbs and vegies.
 had some pallet timber that were in my shed, I got these from a pallet manufacturer, in my area about two to three years ago, they were very fresh and wet, then, now they have completely dried out and good to use for my project.
Trolley size, 110cm long x 54cm wide x 90cm overall height
Materials
Pallet timber  (free) for the planting boxes.
Merbau timber 70mm x 19mm, (pre oiled).
4 Castor wheels - 2 Braked and 2 Non braked.
Screws for mounting wheels
Wood Glue (Wellbond) for the pallet timber.
Polyurethane glue for the pre oiled merbau.
Screws for assembly.
Weedmat material for inside of boxes to protect the wooden boxes
Fixing clips for weed mat.
Tools
Router table for cutting box joints on pallet timber
Router for biscuit joining merbau timber.
Drill for assembly.
Mitre saw.
Various clamps.
Steps
Step 1
Pallet box size,520mm x 540mm x 200mm
Cut pallet wood to suit boxes.
Using router table, cut out the box joints.
Step 2
Glue and clamp boxes.
Step 3
Cut to size the base timber for each box, leaving gaps for drainage.
Step 4
Cut the merbau timber for the trolley
Cut out biscuit joints.
Clamp all timber using polyurethane glue, I found that the wood glue wasn't suitable due to the pre oiled timber.
JoeAzza_10-1687161993270.jpegJoeAzza_11-1687162014496.jpegJoeAzza_12-1687162053882.jpegJoeAzza_13-1687162071383.jpegJoeAzza_14-1687162104526.jpegJoeAzza_15-1687162131544.jpeg
Step 5
Install castors.
Step 6
Cut and fit weed mat into boxes.
Paint trolley and and boxes with decking oil.
Fill planters with potting mixture.
Plant seedlings and seeds, then wait for the magic to happen and follow the sun.
Re: Mobile Herb/Vegie trolley
Hello @JoeAzza
Thank you very much for sharing the steps on how you built your herb trolley. There's nothing like fresh vegetables that you grew yourself. Once it's ready for harvest you just step outside and grab it straight off the growing trolley. I love that you've placed castors on it, it certainly will make it easy to move around especially if you are after the sun.
I look forward to seeing the first harvest.
mich1972
Re: Mobile herb and vegie trolley using pallets
I love this and can’t wait to see what you harvest. It’s amazing what you can create with pallets !!!! 😊🌿
Tyro
Becoming a Leader
You've definitely got the diy bug @JoeAzza!!  That's a beautiful piece of work.  Its given me some ideas for my planting plans come spring.  Are you going to utilise the bottom shelf for shallow rooted plants as well?   And please tell me the need for weed matting in a planter box?
Cheers 🤗
JoeAzza
@Tyro , That’s what happens when you retire, keeping busy😀.
I used the weed mat, to protect the inside of the pallet wood, hopefully the timber won’t deteriorate too quickly.
Tyro
Becoming a Leader
Well I've got to say @JoeAzza that I hadn't thought of that at all!  May I ask how come you went with that choice rather than builder's plastic?
(I'm also retired but my plant collection looks like it's going to take over the house and bury me alive! 😂)
JoeAzza
Hi @Tyro I had some weed mat left from another planter box project, installed approximately 3 years ago, so far no problem, not sure how long it will last.
Tyro
Becoming a Leader
Hi again @JoeAzza!  I haven't explored using biscuit joints, but your use of them has triggered my curiosity.  It looks like a specialised tool is necessary, is that right?  And what benefit are biscuit joints over dowel pegs?
Thanks!  🤗
JoeAzza
@Tyro  I use a Ryobi biscuit joiner to align pieces of timber whilst gluing them, I do welling in a bit stronger, however, I think the glue is doing most of the work,
You could use a small trimmer/router and a jig to make your own slots for biscuit joining. I made one, copied from YouTube.
Tyro
Becoming a Leader
You are far too clever for words @JoeAzza !  Are you an ex-engineer with too much time on your hands or something?! 😂  Your photos make it look so easy, and I thank you for uploading them, but I think I'll just stick with dowel.  I think I know how to use that!  I'm already wondering where I'm going to store all my new tools and implements, and I haven't even got the router yet!  😉
By the way, are you planning on putting any  netting over your plant boxes?  If so, which type do you think works?
Cheers 🤗
