Hi All,
We'd like to redesign our outdoor area to make it feel more like a modern alfresco area. We'd like to start with the flooring before doing anything else.
The floor is stamped concrete and ideally We'd love to tile over this - but have no idea of its possible or where to start?
I thought maybe we could grind down the concrete, but some grooves are quite deep and I'm note sure that would work. If we tile directly on the stamped concrete, I've got a feeling it would come up uneven.....
All suggestions welcome and even alternative options. My husband hates the stamped Concrete look, so something will be done... just not sure what? 🤷♀️ I'll attach pictures of current space, as well as inspo picture of what We'd like to achieve - which was found in the bunnings workshop inspo. (Ignore the kids toys - they're not a permanent fixture!)
Thank you! 😊
Hi @craftycrew
Tile version
At least you have a nice concrete base as a starter.
First I would advise to use self leveling cement for all those nooks and crannies giving you a flat surface to tile too. Smaller tiles will affected by the depth and with of the stenciled surface undulations where as larger tiles will span across the undulations and may not need self leveling cement.
But go self leveling concrete if your budget can afford it or do the project in stages any tiles as it looks like a larger area.
Well if your tiles at lease 300x300mm wide you simply can use a 10mm notched trowel and tile directly over the top using regular tile glue.
If your tiles 400 x 400mm or bigger use 12mm notched trowel.
If you tiles smaller than 300x 300mm 6-8mm notch but must be on self leveling cement.
If you feel happy to tile yourselves i highly recommend A tile leveling system as follow it holds each tile edge together creating a uniform tiling surface. Turns an amature into a near pro.
Hi @craftycrew,
Your outdoor transformation is going to look stunning when finished and we can definitely help you get there. Our resident DIY expert will be back online tomorrow to best assist with your question and @Jewelleryrescue has given some great advice on using self-leveling cement to get a nice even surface to lay your pavers. In the meantime, check out this great video how to prepare and lay a base for pavers as it goes through all the steps from prep to laying to sealing pavers. Experienced pavers @marliemakesit (who will love that her project is part of your inspiration) and @matweb may also be able to lend some suggestions as well.
We would love to see how your outdoor entertaining area transforms so please keep us updated with photos.
Katie
It is definitely possible to pave over stamped concrete it actually would make the job easier you can just lay straight down on top of the concrete with no Prep work just using a tile and paver glue to stick them down if you don't want to glue them all down just do the edge ones to lock the inside ones in place
Hi @craftycrew
Paver Version
I mental substituted pavers with tiles am I bad. so Yes pavers would be a breeze over a stenciled concrete. I would like to ask @MitchellMc to suggest best paving sand to suit this purpose off the top of his head,
To my mind you shouldnt have to go to the expense self leveling concrete a thin layer sand cement dry mix to fill the cracks should provide a strong stable base and as @matweb suggested wet cement the outer edges locking pavers in place. Wetting pavers after wards to activate sand and cement mix.
The sand cement cushion layer can allow pavers to be lifted later if you want a new look . Older pavers can be resold.
The pavers cant go down directly on stenciled concrete as some pavers may tilt as sit proud in the deeper stenciled grooves.
Hi @craftycrew,
Just to clarify, do you wish to lay thick pavers or thin tiles? If you're tiling, then I would suggest self-levelling the area first as there will be tighter tolerances to adhere to. If you're paving, then you could likely get away with going straight over the area.
