hi all!
just hoping for some reassurance that I’m on the right track. I am wanting some screening off our patio area and was thinking of using the Jack screen up system.
Would I be right in thinking I will need the following:
- 4 x rear fixing brackets (16mm if I’m using 15mm slats or 19mm if using 17mm slats) to be fixed to the wooden beams and side of house (colourbond) as pictured.
- 44 x screening slats (the guide says 22 approx needed for 2m @ 70mm)
- 4 x brace (due to the width of the slats between the brackets, I measured the width as approx 208cm)
That looks about right, @karrathaliss! They are super simple to install, and I can't wait to see your results. Shout out if you get stuck at all!
