How to repair rotten timber underneath roof frame?
bh039
I noticed this rotten wood at the fiasco, probably caused by the gutter leakage. How can I fix the rotten wood as well as fix the leakage?WhatsApp Image 2023-07-14 at 12.03.25 PM.jpegWhatsApp Image 2023-07-14 at 12.03.25 PM (1).jpeg
Any help is appreciated.
Re: How to bog this rotten wood and stop water damage from gutter
Hello @bh039
Thanks for sharing your question about what bog to use on your timber rot. Generally, I recommend using Earl's 250ml Wood Hardener along with Turbo Builders Bog. This combination is often a good way to repair timber rot in window and door frames.
However, the damage to the corner of your timber roof frame is extensive and has gone past the mounting screws holding the other timber in place. In this situation, I suggest having the damage assessed and repaired by a registered builder as soon as possible. I don't recommend using bog on the damage as it is now structurally unsound.
