Hi everyone we bought a house and the previous owners have painted the driveway but the paint is peeling off however there are three layers of different coloured paint the first being easy to remove with the hose the second a little more stubborn and the third more stubborn. I'm looking for the most cost effective way to make thus drive look at least decent so any suggestions would be appreciated. Thanks
Hi @kathy7,
The easiest way to give your driveway a refresh is to paint over what is already there. The problem with this is that your new layer of paint is adhered to the layer beneath, so it will only be as good as the coat of paint that it is adhered to.
You've indicated that the top layer of paint hasn't adhered well to the layers beneath, but the layers beneath are better adhered.
My suggestion would be to use a high-powered pressure cleaner such as this Full Boar 3200PSI 7HP Petrol Pressure Washer to go over the driveway and remove as much of the poorly adhered paint as possible.
Once the poorly adhered paint has been removed, you can use a concrete primer designed for use over existing coatings. This Rust-Oleum 3.78L Concrete and Garage Recoat Primer is a good option.
Now the surface has been primed, you can use a concrete paint in a colour and finish of your choosing to recoat the surface. Ensure you follow the manufacturer's instructions closely to ensure you get the best result possible.
Thank you
