How to improve patio drainage?
neal
Growing in Experience
My outside enclosed patio has drainage issues when I want to flush it out due to corrugated walls enclosing the patio. It can slowly drain underneath but takes too long. Looking for ideas or recommendations for someone to install drainage pipes through the concrete floor and through limestone retaining wall for the water to escape outside.
Re: patio drainage
HI @neal
You want to flush the area out?  So that means you are hosing out the patio area it seams to me?  But in any case consider the following.
Well see the timber rail along the bottom  well i would cut it at each end and lift it up  higher creating a bigger gap 30mm or so and any water will flow out faster out down  the wall corregations  then no drain required.
Additionally this  will also help stop timber rot if it is not fully painted underneath.
You will need to carefully remove outside wall fixings to the timber as to minimise any damage to the metal and when the timber raised re fix the iron to the timber.   I would spray silver zinc paint on the exposed holes and cover the  holes with silver duct tape.
Hope you area fixed soon
neal
Re: patio drainage
Thanks but it’s metal. And we get snakes so hence the small gap so we don’t get visitors.
Re: patio drainage
Hi @neal,
It's not really a permanent solution to the issue, but have you considered a wet and dry vacuum?
This might be a simple and cost-effective solution for when you need to clean the area.
Let me know what you think.
Dave-1
Community Megastar
Re: patio drainage
Afternoon @neal
How about cutting slots in the tin walls and timber bases and installing steel mesh so it will exclude snakes? You do run up against the mesh clogging due to hair ect but maybe that could be worked around?
neal
Re: patio drainage
Thanks for that. It’s an option.
neal
Re: patio drainage
I think I’m going to get some core holes drilled into the sand base and from the side like my patio concreter has suggested. Then use a flexible pipe to allow water and hair to escape. I imagine I can get a screwable/lockable grate to print anything climbing up the pipe at the top. Does this sound good.
neal
Re: patio drainage
Does my hole coring suggestion sound a good option.
Re: patio drainage
Hello @neal
The issue I see with the sand base is that the covers will move and might not stay level. Have you considered using a surface drain instead such as the Everhard 3m EasyDRAIN Compact Polymer Grate And Channel. It will be easier to anchor into place and the drain can be directed to an existing storm water outlet.
However, before you make any changes, I suggest engaging the services of a plumber as they are the only ones certified to link your drain to your storm water outlet.
Dave-1
Community Megastar
Re: patio drainage
Evening @neal
Whichever way you go a longer grill to capture the water and "other bits" lol would be something Id factor in.  And with the piping I find the small corrorgated flexible pipe that was installed next to my pool tends to clog up with leaves and seed easily. When I redo it I would be using a 90mm pipe at least and probarly a 100mm PVC style pipe. Capacity plus not getting clogged is what I am after.
