My outside enclosed patio has drainage issues when I want to flush it out due to corrugated walls enclosing the patio. It can slowly drain underneath but takes too long. Looking for ideas or recommendations for someone to install drainage pipes through the concrete floor and through limestone retaining wall for the water to escape outside.
HI @neal
You want to flush the area out? So that means you are hosing out the patio area it seams to me? But in any case consider the following.
Well see the timber rail along the bottom well i would cut it at each end and lift it up higher creating a bigger gap 30mm or so and any water will flow out faster out down the wall corregations then no drain required.
Additionally this will also help stop timber rot if it is not fully painted underneath.
You will need to carefully remove outside wall fixings to the timber as to minimise any damage to the metal and when the timber raised re fix the iron to the timber. I would spray silver zinc paint on the exposed holes and cover the holes with silver duct tape.
Hope you area fixed soon
Thanks but it’s metal. And we get snakes so hence the small gap so we don’t get visitors.
Hi @neal,
It's not really a permanent solution to the issue, but have you considered a wet and dry vacuum?
This might be a simple and cost-effective solution for when you need to clean the area.
Let me know what you think.
Afternoon @neal
How about cutting slots in the tin walls and timber bases and installing steel mesh so it will exclude snakes? You do run up against the mesh clogging due to hair ect but maybe that could be worked around?
Thanks for that. It’s an option.
I think I’m going to get some core holes drilled into the sand base and from the side like my patio concreter has suggested. Then use a flexible pipe to allow water and hair to escape. I imagine I can get a screwable/lockable grate to print anything climbing up the pipe at the top. Does this sound good.
Does my hole coring suggestion sound a good option.
Hello @neal
The issue I see with the sand base is that the covers will move and might not stay level. Have you considered using a surface drain instead such as the Everhard 3m EasyDRAIN Compact Polymer Grate And Channel. It will be easier to anchor into place and the drain can be directed to an existing storm water outlet.
However, before you make any changes, I suggest engaging the services of a plumber as they are the only ones certified to link your drain to your storm water outlet.
Evening @neal
Whichever way you go a longer grill to capture the water and "other bits" lol would be something Id factor in. And with the piping I find the small corrorgated flexible pipe that was installed next to my pool tends to clog up with leaves and seed easily. When I redo it I would be using a 90mm pipe at least and probarly a 100mm PVC style pipe. Capacity plus not getting clogged is what I am after.
