How to fix Matador barbecue stuck on low heat?
geoffrey888
I bought from you a matador 4 burner  . connected to a gas socket.the gas goes to the bbq
but never gets hot.the gas burner is alway on a low heat.
what should I do?
help
geoffrey
Re: How to fix Matador barbecue stuck on low heat?
Hi @geoffrey888,
I'll start by saying that any interactions with gas should be made with extreme caution. Ensure that the gas is turned off while troubleshooting and if you are not confident troubleshooting the issues, consider contacting a professional for assistance.
It sounds like the issue is with the gas flow which could stem from a couple of things, the regulator, blocked burners or low pressure from the gas socket.
To check your gas regulator, first turn off the gas supply and inspect the regulator for any visible damage. Check the hose to ensure it isn’t kinked or damaged. Perform a soap test by applying soapy water to the connections and watching for bubbles, which would indicate a gas leak. To reset the regulator, disconnect it from the gas supply, wait 30 seconds, then reconnect and turn the gas on slowly. Afterward, test the BBQ to see if it heats properly. If the issue remains unresolved, replacing the regulator may be necessary.
With everything still disconnected, check the burners for blockages. Brush the burners with a stiff-bristled brush, focusing on the holes to remove any potential blockages. Once cleaned, reconnect the gas and test.
If these two steps don't fix the issue, you may have low gas pressure. If this is the case, you will need to contact a licensed gas fitter for their assistance.
Let me know how you go and if you have any further questions, please don't hesitate to ask.
Jeed_chamunee
Community Newcomer
Hi, I have the same issue. Bought  it less than a year. Only 1 time using. Not go to the heat level anymore. Try to clean all the hole to make sure it all not block. But still the same.
Hello @Jeed_chamunee
If the unit is less than one year old, I suggest bringing the unit back to the store for an exchange. Please make sure to bring your docket or a bank statement indicating proof of purchase.
Hi @Jeed_chamunee,
Let me also extend a very warm welcome to the community.
Have you tried all the troubleshooting steps that Jacob suggested above?
Could you also please let us know whether you are using gas bottles or a built-in gas supply line?
Thanks,
