Hi @ricm,
I've been in contact with Ekodeck, and they've had feedback from installers that the boards can be curved and bent to a significant radius. You've got some relatively tight curves, but it should be possible to get them to suit. The boards can also be heated to allow tighter bends.
If you fix a fascia board at one end of your curve and bend it around it, how far off are you from making it fit? Rachet straps can help you pull it into position.
Afternoon @ricm
Mmmm thinking
First option
So instead of the amount of curves you want, how about reducing the curve distance down to a tighter bend with longer straight runs. That way you are now only deal with a smaller area. With the smaller, sharper bends The facia will be easier to install. Now the problem is how to do the sharper bend?
Second option
How about switching from the eco-deck to a differant material for the facia/trim area?
Brutus 50 x 6mm x 2.4m Building Moulding Cover Trim You would need two of these side by side but it sounds like its a lot more fleiable and is only 6mm thick.
Which leads me to teh next part of the suggestion, head on into your local Bunnings and walk around the timber yard, see what materials that can be used that have "flex"" to them and can handle external conditions. I am thinking of some of the thinner firbro look materials and wondering if they could be used? That way you get to keep your long bends the way you want them.
So easy answer is to change material for the facia. It could solve your issue
Afternoon @ricm
I hadnt refreshed my page when I was writing the response, I would strongly suggest to go with @MitchellMc's recomendations, especially for consistancy. I use ratchet straps when im getting my mmerbau boards straight a LOT. and it really works. If you look through my Privacy screen project it shows how I used the ratchets.
