I am looking to make a cat enclosure outside a window
looking to make a cat enclosure using pvc pipe but really sure which pipe I need to use. Looking at ht 2300 x L3000 x W 1200.
Welcome to the Bunnings Workshop community @Cathouse. It's terrific to have you join us, and many thanks for your question about creating a cat enclosure.
You might like to take a look at this amazing indoor to outdoor cat tower by @Shannon; it's a sensational project.
Regarding your PVC enclosure, I recommend you use 40mm PVC pipe, as it is reasonably rigid and should allow you to span a decent distance (around 1200mm) before it starts sagging. You'll also need a number of Holman 40mm 90° White PVC Elbows and Holman 40mm 88° Female and Female PVC DWV Plain Junctions. Alternatively, Holman 40mm EzyFit 3 Way PVC Joints can be used for your corners. You'll need to use solvent cement to glue all the joints together.
I've created the rendering below to help illustrate how the unit could be put together. Mesh can be cable-tied to the exterior.
Hello @Cathouse 🖐
What a wonderful project, just curious what type of base you had decided on? perhaps parallel cement pavers? compacted gravel? 🤔
We too have a Cat Enclosure along the side of our house, a wooden treated pine frame and fence slat construction (for improved air flow), insect screens have been an ongoing repair since first construction with the uprated pet-mesh fairing the best overall.
Hello,
Love the idea, how is the door mounted?
Thanks,
Jase
Hello @Jase74
I suggest looking at the Lane 75 x 47 x 1.6mm Zinc Plated Loose Pin DURAsmooth™ Non Mortice Hinge or the Pinnacle 70mm Fixed Pin Butt Hinge. It all depends on the size of pipping you'll be using for the cage. In regards to mounting the hinges, I suggest using a nut and bolt configuration so that they don't pull out.
