I am thinking of buying the Mimosa 3 x 3m Lava Portsea Louvre semi permanent gazebo- Mimosa 3 x 3m Lava Portsea Louvre Semi Permanent Gazebo - Bunnings Australia
I know the wind rating is not as good as some other pergolas, but it would be located in a very sheltered area that has a big concrete slab. I could dynabolt straight into the slab, but given the semi permanent branding, my preference is to cut holes and extend and sink the feet into cement, using steel plates.
The gazebo/pergola looks straightforward to assemble, but there are always little tricks and traps.
All feedback welcome, particularly if anyone has actually assembled a Mimosa 3x3 Lava Portsea
Hi @petemel49,
It is important to note that semi-permanent gazebos, such as the one you are looking at, will often require approval from your local council. We have copies of the engineering plans that can be submitted for this application which can be provided upon your request.
When installed as a semi-permanent structure, the engineering plans for the Mimosa 3 x 3m Lava Portsea Louvre Semi Permanent Gazebo call for a concrete pier that is a minimum of 450mm in diameter and 600mm deep, so cutting holes in the existing slab and pouring a dedicated pier is essential.
I have built them for display in-store, but never in a semi-permanent setting, but the only real difference is the anchoring. I can say that the construction is fairly simple and following the installation instructions is relatively easy. I am happy to assist along the way if you run into any issues.
Let me know what you think.
Hello @petemel49
I've emailed you a copy of the engineering plans for the Mimosa 3 x 3m Lava Portsea Louvre Semi Permanent Gazebo.
Hey Eric, Many thanks for the plans. It is a toss up between the Mimosa or the Toja Grid Wall Mount pergola kit. Do you have plans for the Toja Grid Wall Mount? I understand the ground anchoring requirements (400 wide x 600 deep hole filled with concrete). The TG Wall Mount means two less holes.
tks in advance.
cheers
Pete
Hello @petemel49
The engineering plans for a Toja Grid pergola depends on your local council’s building regulations and the size of the structure. If you’re installing a small, freestanding pergola that meets exempt development rules in your state (typically under a certain height and size limit), you may not need engineering plans.
However, if your pergola is large, attached to a building, or in a cyclone-prone or high-wind area, your council may require engineering certification to ensure it complies with structural and wind load requirements.
It’s best to check with your local council or a private certifier to confirm what’s needed for your specific installation. If engineering plans are required, Toja Grid doesn’t provide certified plans, I therefore suggest engaging the services of an engineer to design your pergola.
Please note that the Toja Grid kits do not include Timber and Anchoring hardware.
Many thanks for the sound advice!
