How do I install an area of pea gravel over sand?
JamesP
Hello, I'm looking to install pea gravel in this sandy area in the photo beloow outlined in red.
1000022648.jpgContext: we're in the Perth hills and the rest of the garden is pea gravel and coffee rock but the previous owner dug this area up, plonked down sand and tried to grow a lawn which failed. I'd like to replace/cover the sand with pea gravel.
Questions:
1. Do I need to add a base of gravel or limestone grit to prevent the pea gravel sinking into the sand?
2. Should I also consider weed matting?
3. What depth of pea gravel/base do you recommend? This will determine how much sand to shift
4. Should I try to remove all the sand or is this not necessary? I don't know how deep it goes
4. Anything else to consider?
Thank you in advance 🙏
Re: How do I install an area of pea gravel over sand?
Hello @JamesP
That's an interesting question, I suggest removing the sand if it does not interfere with its current level with the surrounding soil. But if the sand is needed to keep it level, then you can proceed to use weedmat. I suggest a level of 30mm so that when it settles and spreads out you should not be able to see the weedmat. To prevent the weedmat from moving I suggest using Lotus Collection 14cm Weedmat Pin. One other thing you can try is to use a tamper on the sand to compact it.
Thank you Eric. I'll give it a go. One last question. Would you consider using a geotextile instead of weed mat? It could be more durable?
Hi @JamesP
Using geotextile should work just as well if not better. Your absolutely correct that it is much more robust than weedmat. Between the two I suggest using geotextile.
Thanks Eric. I'm just getting around to this now. Is there a type of geotextile you can recommend? I'd like one that drains well.
Hi @JamesP,
It's brilliant to hear you're ready to get started with your project.
Either this Grunt Non Woven Geotextile Membrane Drain Mat Fabric or this Everhard Roll Drain Matting are good options that will drain well.
Let me know what you think.
