I need to add something to this to make it at least 1.8m and non climbable as it will be in a pool area.
I was thinking some kind of panels but not sure how I could attach to make it look seamless.
Alternatively i could do some 1.8m pine palings but not sure how I could attach as there isnt really an existing rail thick enough.
What do you reckon?
Jon
Hello @j1111
Your current fence layout is not pool compliant because of the way the timber slats have been laid out. However, it appears that you have very large timber fencing posts. I propose installing 72 x 47mm 5.4m Fence Rail H3 Treated Pine Premium Grade CCA in combination with 150 x 12mm 1.8m Fence Paling H3 Treated Pine CCA in a classic overlapping pattern.
The reason for doing an overlapping pattern is to make sure that there is no opportunity for children to access the horizontal timber slats on the other side. I also suggest putting a timber cap over your fence to protect the top of the palings.
Good Evening @j1111
I agree with @EricL's recomendation to make the fence compliant. I am a little unsure on how solid the posts are as the timber posts look a little aged. If there is any wobble to them at all I would be installing new posts?
I really like the overlap of the palings. No way hands or feet can get into the bits between that way.
