Hi Mitchell.
Saw this at Bunnings the other day and just wondering if "Cheetah" is a revamped Ozito?
Cheers.
It looks oddly similar, doesn't it @Noyade? An excellent compact saw all around, especially for tight spaces and pruning smaller limbs.
Best little chainsaw I've ever owned (Ozito).
Will the Cheetah be the same?
There are some cosmetic differences, but...
Just a chainsaw question - I have seen "L" "H" and "T" on the sides of chainsaws - adjustment holes with the appropriate tools - to do what exactly?
Ozito does not supply the Cheetah, so I can't confirm whether it will be the same @Noyade. However, provided it has the same engine size, I'd imagine it will be almost identical in operation.
The letters on the screws represent High (H) and Low (L). The H screw regulates the air/fuel mix during high RPMs, while the L screw does the same during low RPMs.
Thanks for that @MitchellMc
"regulates the air/fuel mix"
For better power and efficiency?
The reason I inquired is I have an old Talon that has slowly been increasing it's idle speed - so much so I noticed yesterday with the finger off the throttle the blade still tries to rotate.
H and L looked beyond me, but T is a Phillips head, and I found rotating it anti-clockwise solved the problem.
Cheers.
