Nest of 3 planter stands
JoeAzza
I had these small off cut timber boards that were destined for firewood. I was going to make chopping boards out of them, however, I wasn’t sure of the type of glue was used to laminate them together, so I decide to make this set of planter stands, I got the idea from the internet. I used Tasmanian Oak. This project took me six days to complete.
Materials
Offcuts of stair treads, TAS Oak.
12mmx40mm tas oak for splines
Water restraint glue, Titebond II
Water based clear satin varnish.
Sandpaper various grit.
Super glue
Tools
Table saw, Triton
Mitre saw, Makita
Router Table
Small router for spline
Spline jig, home made
Clamps
Sander 125mm Makita
Steps
Step 1
Cut angles on each board on Triton Saw table
Step 2
Glue up and clamp together for two of the stands, for the third stand I used superglue with a spray accelerator and the wood glue, this worked well , no clamping required.
No clamps used for this one, just super glue and wood glue
Step 3
Make up spline jig and cut and glue splines
Spline jig
Step 4
Sand  and paint, I used water based clear varnish, applied with a piece off cut sponge, (no brush marks)
Re: Nest of 3 planter stands
Hi @JoeAzza,
Thank you for sharing your nested planter stand project.
Tasmanian Oak is such a beautiful timber and you've done a great job accentuating that with the lack of mechanical fixings and the clear varnish.
This is a sleek project that will certainly beautify any room that they occupy.
Congratulations on a fantastic project and again, thank you for sharing.
