Hello, my carpet is burnt, Can you please guide how can I fix this which tools do i need. Thanks
Hi @neter
If that carpet is truly melted together down deep there is not a lot to help that spot.
1 , Cover the spot with rug.
2 Try using a kitchen fork and hold it upright and try to rake the fibres free from each other if they lightly fussed. So scuff up the melted patch it may work If only top fibres lightly fussed the carpet will never look as good again sorry to say. If the carpet responds and starts fluffing up again you may end up with some pilling (little balls of fluff on top of the carpet) after wards use a face shaver and shaver the pilling off gently evenly. Some times work in case of fresh glue dropped too or chewing gum.
3 Last ditched effort not for the faint hearted this may ruin your carpet 100% and maybe better to leave melted spot until the time you replace carpets.
If you have spare carpet of the same (I burnt the carpet black in a hand size spot as a kid science experiment gone wrong I thought my parents would kill me lol) So I used a fresh super sharp box type cutter and cut out the burnt section of carpet in a square shape is easiest. I then laided out the cut out bit on the spare carpet matching the pattern position too and cut a 2mm larger all round new carpet patch and glued it in with araldite fluffing the edges together know one ever noticed todate I could see it though Gulp. , The slighly larger size sprung out wards making a neat compressed fit to carpet surrounds.
Sorry to hear about your burnt carpet, @neter. Our resident Bunnings D.I.Y. expert @MitchellMc will also be happy to provide some advice as soon as he can.
Welcome to the Bunnings Workshop community. Trust you'll find it a useful resource for all your home improvement and garden projects. Don't hesitate to let us know if you need a hand getting the most out of the site.
Akanksha
Hi @neter
If you are looking for a seamless repair, then that's a job for a professional. They'll be able to take a piece from somewhere else, like a cupboard, and cut out the damage and glue in the new section.
It's possible to do this yourself, but it's a little difficult to match the pattern and your repair will likely be noticeable.
Afternoon @neter
Ouch! 😕 Thats about all that I can say.
I have melted my nylon carpet to a sheet of plastic by leaving a 1500 Halogen flood light sitting on the floor when I was painting one time.
The carpet wasnt as compressed as your instance is but I did manage to fix it by using a brand new blade of a safty knife and giving the carpet a hair cut just below the melted part.... Not confidant it will work in your instance but could be used as a last resort.
Slow and steady and maybe practice on a piece of spare carpet you may have to get a feel for it.
I want to fix burnt carpet it's very small patch
Good Morning @simran5
Welcome to the community Its a good place to find out information like this Would it be a possible for a couple of photos to show the level of damage to the carpet? It would help with ideas on how to tackle the issue.
Hi @simran5,
A warm welcome to the Bunnings Workshop community.
As @Dave-1 has already mentioned, it would be difficult to offer advice without seeing the problem. If you need a hand uploading images, please let me know so I can assist.
Unfortunately, it is likely that you will need the help of a professional carpet repairer. They use specialised tools and techniques that are not something I can recommend as a D.I.Y. solution.
If the problem is minor, there may be a workaround, but it is fairly likely you'll need the assistance of a professional.
