DIYMum
Having an Impact
How to paint faux brick wall?
Am wanting to improve the aesthetics of this faux brick wall between two living areas. I'd prefer not to pull it off and was thinking of painting over it. I'm assuming I'll need to prime the faux brick before painting with some sort of bonding primer? Any other suggestions for an easy low-cost face lift?
Apricot coloured walls will be repainted Antique White once the weather warms up (not for at least another 3 months or so!)
Thanks!
286686393_10224878955853687_8638627904246589970_n.jpg 285577304_10224878960653807_4569648062803529803_n.jpg
Re: Help with faux brick wall
Hi @DIYMum
Thanks for sharing your question about painting your faux brick wall. Preparation is key when painting a faux brick wall, I suggest using a stiff broom to remove any dust or debris that may be stuck to the wall. I then propose vacuuming the wall and the surrounding area to pick up any bits of plaster that may have fallen into the crevices of the wall.
I recommend using an undercoat sealer, this will seal the porosity of the faux brick and you won't have to use a great deal of top coat paint to cover the area. You can also use a purpose-made sealer such as Crommelin 4L Brick And Render Water Based Sealer. Once the sealer cures you can paint over it using any water-based paint.
The good news is that you already have a sprayer and because you have this tool, it will definitely cut down the painting time for your wall.
Here is a link to our best advice: How do you paint internal bricks?
Here is a handy step-by-step guide: How to paint your house’s exterior with a spray gun.
