How to install 9mm acoustic pinboard?
Vineyardpaul
Howdy,
I want to install these on my ceiling to help with soundproofing:
https://www.bunnings.com.au/1200-x-800mm-9mm-acoustic-pinboard-white_p0098213
https://www.bunnings.com.au/2420-x-1220mm-9mm-acoustic-pinboard-white_p0098204
How do I hold them up, and how do I fix them? Glue, screws, double-sided tape?
Re: 9mm Acoustic Pinboard - Installation Help
Hi @Vineyardpaul,
You could use any of the three products you have described as these boards are very lightweight and won't require a whole lot to keep in place. A combination of glue and screws will yield the best results but may be overkill in this situation.
My suggestion is to use Plasterboard Screws, screwed through the acoustic board into the ceiling battens. You can locate the battens easily with the use of a Stud Finder.
You might like to check out How to use a stud finder for some guidance.
The reason I'd suggest screws over simply gluing is that they will not be affected by gravity over time, whereas glue alone would likely pull away from the plasterboard over time. A screw solidly embedded into timber, will not do this over time, whereas glue or double-sided tape will.
If you want the best connection possible, it can't hurt to use some Liquid Nails alongside the screws, but it is entirely up to you.
