How to cut Smart Home Products 9.5mm 2.887m2 Soundguard planks?
Yuggle
Hi. I've installed villaboard and sealed joins and edges and am soon to install the floating floor. I'm considering getting a new mitre saw (my old one is pretty shonky) as I'm not confident I'd do a good job with either my jigsaw or a hand-saw. I may use my circular saw. I did see a video where they simply score and snap the planks. Is this possible with the planks I'm using?
Yuggle
Re: How to cut Smart Home Products 9.5mm 2.887m2 Soundguard planks?
Hi. Decided to buy a new Ryobi One jigsaw (cheap-as-chips at $79) which works a treat (the old corded thing I have is a shocker). Also realized, most if not all cut ends should be facing the walls, so will be covered by the beading I intend. My problem now is I can't seem to get the planks to join properly. I'm using a rubber hammer and giving them a good whack over the join (not to either side of the join). Though I was told I could use up to 2mm underlay without voiding the planks' warranty, I'm beginning to think that may have been wrong. These planks come with underlay attached. While I would value the second layer of 2mm underlay for improved sound-proofing, it may be that with both the attached underlay and the additional 2mm, there is too much give when I hammer to join the planks properly. Any thoughts here much welcome. Best.
Hello @Yuggle
The Smart Home Products 9.5mm 2.887m2 Soundguard already has an underlay attached to it. Putting another layer of underlay underneath is counterproductive as it will not allow the floating floor to slide smoothly. As you mentioned there would be too much give and the flooring will not lay flat properly. I suggest removing the loose underlay and using only the plank so that they lock in properly.
