Hi team, can you please help me build a simple floor desk, with these measurements
width : 50 inches
depth : 25 inches
height: 12 inches
Welcome to the Bunnings Workshop community @bhargavi. It's wonderful to have you join us, and many thanks for your question about building a desk.
So that's 125cm in width, 62.5cm in depth and 30cm in height. We have a number of timber panels that you could use for the top that closely resemble those measurements, such as the Specrite 1200 x 600 x 18mm Timber Multi Use Pine Panel, SpecRite 1200 x 600mm 18mm Timber Panel Okoume FJ Laminated and Specrite 1200 x 600 x 18mm Hevea Multi Use Panel.
I can't find any legs that would be spot on your 30cm in height. There's a range of timber legs that could be cut down to suit, such as the Adoored 53 x 360mm Raw Wood Round Furniture Leg. Or if left at full length, the leg and top would be about three inches taller than your requirement. Or, you could go with a shorter leg such as the Adoored 60 x 230mm White Round Metal Furniture Leg, which, when combined with the top, will be about two inches shorter than your requirements.
Thank you Mitchell,
Just a question, would Bunnings be able to build this up with these items, so I can buy. Is there such an option?
https://www.bunnings.com.au/specrite-1200-x-600-x-18mm-timber-multi-use-pine-panel_p0419619
And four legs - https://www.bunnings.com.au/adoored-53-x-360mm-raw-wood-round-furniture-leg_p0197177
Unfortunately, not @bhargavi. We'd be more than happy to provide advice and guidance on Workshop to help you complete the project yourself.
I've just realised that I didn't mention the leg plates you'll need. These attach the legs to the top.
