How to build a barn door?
shaqqi
Hi All
This can be my first DIY Bunning project.
I would like to make a wooden stain type barn door. Size of opening is width 980 mm width and height 2120 mm
Plz suggest what shall be the ideal width and height I shall go for and what material I shall get from bunnings . Thanks
Re: How to build a barn door?
Hello @shaqqi
I suggest using 240grit sandpaper to prevent sanding too deeply into the timber surface.
shaqqi
Thanks  Eric for the advise.
I’ve completed the staining and subsequent steps. Most of the marks seem to be well-covered now. I’ll share photos soon after applying the final clear coat.
Now come the installation query. I have seen the Bunning installation guide video and i like the idea of using a SUPPORT HEADER.
Can you please advise which wood and size dimensions of wood bar shall i use ( Door is made of pine lining board and frame Pine DAR). Please share the link would be helpful so i just simply buy it and do stain meanwhile . (For info my door width is 1100 mm so i am using 2440 mm roller track length therefore 2.4 m length wood bar is needed
Hassan
Hi Hassan (@shaqqi),
You could either use a 140 x 19mm 2.4m DAR Pine Premium, or my preference would be to go with 110 x 19mm 2.4m DAR Tasmanian Oak Select, which is a slightly harder timber. Just ensure that whichever track system you choose the timber is tall enough to suit the provided mounts.
shaqqi
Hi Mitch
Tasmanian oak link which you shared is not opening and tried myself to search on Bunning site it is not coming as well may be it is out of stock
Pine will be my preference as it will give same texture after staining as like the door. As long as it is durable that's the main point i want to know.
Can you please suggest the suitable bolt i shall use to fix to wall as well
Hassan
Pine will be suitably durable Hassan (@shaqqi). Just ensure it is well fixed to the timber studs in the wall. I'd recommend two screws into each stud along its span.
shaqqi
OK..
Can you please suggest and share the link of screws
Hassan
These 75mm timber screws would do the job Hassan (@shaqqi).
