How to affix long melamine boards for wardrobe shelves?
danitog
Hi  we’re wanting to DIY some custom (adjustable) shelves for the kids existing wardrobes.
We’ve figured out the plan, how we want it to look and the material we want to use but what we’re struggling to figure out is the best way attach/affix the melamine board that will be “freestanding” in the middle of the wardrobe.
The clothes rail that is currently there will be cut down and shortened.
One melamine board will be against the wall - plan to cut the existing skirting so it fits flush again wall and then use some liquid nails and chipboard screws to attach to wall.
The shelves are no problem.
The floor is being replaced to be the same boards as the rest of the house.
But how to fix the other side of the shelves?
We’re currently thinking L brackets (4 at top attached to existing shelf & 2 bottom attached to skirting & wall).
Unsure if this is the best way
Thanks!!
Re: How to affix long melamine boards for wardrobe shelves?
Hi @danitog,
Your plans look well thought out and the method of installation you've described is more or less what I would recommend.
I'd suggest cutting the CUSTOMpine 16 x 2400 x 595mm E1L System 32 HD Shelving White Carcass Matt Particleboard Standard so it is a tight fit, ensuring you cut them so the holes will line up when installed. I have found it is best to mark sheet products in place so you can visualise their orientation. If you can't mark them in place, ensure you orient them how they will be while installed before marking and cutting them.
You can then use Zenith 50mm Zinc Plated Angle Brackets to attach the freestanding melamine sheet to the floor and the shelf above. You can use 15mm Button Head Stitching Screws so they do not poke out the opposite side of the melamine. To give the most strength possible, I'd suggest using at minimum 3 angled brackets into the ground and 3 into the shelf above. It looks like you have timber floors, so screwing the brackets into the floors will give a better hold than going into the wall behind.
Using Liquid Nails and screws to attach the melamine sheet against the wall on the right is fine, but you will require longer chipboard screws such as these Zenith 8G x 40mm Countersunk Rib Head Chipboard Screws. Ideally, they will go through the plasterboard into a stud. You can use a stud finder to locate a stud behind the plasterboard.
You can then use your choice of shelf support to hold up your shelves.
danitog
Thank you!
I was happy to heard my thoughts on this made sense.
Just finished the first one and I’m pretty happy with it!
perfect? No. But considering this is my first proper diy other than painting, and we got to say goodbye to the yellow paint with green carpet - very happy (plus happy a toddler/kid can’t pull them over like a chest of draws).
There were no studs on one side of the melamine unfortunately so the piece that’s fixed to wall has 3 screws into studs and 2 toggle anchors.
thank you!
Hi @danitog,
Great job with your custom shelves.
They look pretty much perfect to me and I'm sure the added safety around your toddler is a huge relief.
Thank you for the update.
