How I can get home solutions mesh basket apart?
Is anyone able to tell me how I can get home solutions mesh basket apart from the others please?
- Labels:
Organising
Repairing
Tools and Materials
Re: How I can get home solutions mesh basket apart?
Hello @DelWood
Welcome to the Bunnings Workshop community. It's sensational to have you join us, and thanks for sharing your question about the mesh baskets.
I propose holding one of the corners of the top basket with your left hand and tapping the corner of the second basket underneath with a rubber mallet. You can also use a small timber offcut to gently tap the top corners loose. Repeat the process for each corner until the baskets come loose.
Good Evening @DelWood
A couple of ideas to add to the good ones from @EricL and @Nailbag
Leave the baskets in the sun for several hours then followeither of @EricL's or @Nailbag methods. Alternatively if you live somewhere wher it gets cold, leave them out overnight and try first thing in the early morning. Generally a little pressure from diagonally spaced corners has worked for me. Its how I have been taught to pull motor bearings off and wheels from cars as well. Slow and steady, tap gently with something heavy but not supper heavy
Good luck
