Air vents
Shane
Having an Impact
Air vents
Can I block up the vents in my old double brick house? I am not sure why they are there, but I imagine they are not good for losing heat and probably lead to dust.
Fyre
Cultivating a Following
Re: Air vents
Do you have an open fire place?.
Shane
Having an Impact
Re: Air vents
There is, but we don't use it. So you think the vents are only necessary for ventilation for when you have a fire?
Shane
Having an Impact
Re: Air vents
Here's an example from our bedroom...
Dan
Re: Air vents
I would recommend against blocking up those vents as it will lead to a build-up of moisture which then leads to mould. The property my friend rents has those types of vents painted over and sealed and she is constantly dealing with moisture and mould, it’s not pretty. An alternative solution is to maybe get something that can go over those vents that can still allow for ventilation but keep out dust and other particles.
Kermit
Re: Air vents
Safer option might be to use these as they are removable if you have any dramas down the track.
Re: Air vents
Fire or unflued gas or electric space heating that will deplete the oxygen in the air and send you permanently to sleep overnight.  They were replaced in modern house by slits in their aluminium window frames.
Re: Air vents
I completely agree with @Dan. I would be guessing that you have limestone footings which act as wicks drawing water up (especially if you are close to the water table). These vents are extremely important to allow the moisture to vent out of the cavities of your home preventing water damage and more importantly, mould. This is currently a major problem with a heritage building in Fremantle we are currently working on.
