Air vents
Can I block up the vents in my old double brick house? I am not sure why they are there, but I imagine they are not good for losing heat and probably lead to dust.
- Labels:
Building and Construction
Renovation
Re: Air vents
Do you have an open fire place?.
Re: Air vents
There is, but we don't use it. So you think the vents are only necessary for ventilation for when you have a fire?
Re: Air vents
Here's an example from our bedroom...
Re: Air vents
I would recommend against blocking up those vents as it will lead to a build-up of moisture which then leads to mould. The property my friend rents has those types of vents painted over and sealed and she is constantly dealing with moisture and mould, it’s not pretty. An alternative solution is to maybe get something that can go over those vents that can still allow for ventilation but keep out dust and other particles.
Re: Air vents
Re: Air vents
Fire or unflued gas or electric space heating that will deplete the oxygen in the air and send you permanently to sleep overnight. They were replaced in modern house by slits in their aluminium window frames.
Re: Air vents
Subject | Author | Posted | |
February | |||
August 2023 | |||
February 2023 | |||
October 2021 | |||
July 2021 |
