How to remove vertical sliding window locks?
paul2r
Hi All,
Sliding key lock faulty ...window will not open ....want to remove ...possibly old type lock !!!
Re: How to remove vertical sliding window locks?
Welcome to the Bunnings Workshop community @paul2r. It's sensational to have you join us, and many thanks for your question about removing locks.
You might like to upload an image of the lock so our helpful members have a better idea of what you're working with. Let me know if you need a hand posting an image.
If the sliding key lock is faulty and the window won't open, one option is to drill out the lock barrel. To do this, use a small metal drill bit to carefully drill through the centre of the lock. Once the barrel is drilled out, it should release the locking mechanism and allow you to open the window. Afterwards, you’ll need to replace the lock with a new one. Make sure to measure your current lock to get the right size replacement.
It’s crucial to be exceptionally careful when working around glass. Always wear appropriate PPE, including safety glasses, cut-resistant gloves, a long-sleeved shirt, trousers, and enclosed footwear, to minimise the risk of injury from broken glass or sharp edges.
Alternatively, if you’re unsure about drilling or concerned about damaging the window frame, enlisting the services of a locksmith could be a safer option. A locksmith can either unlock the window or potentially cut a new key, depending on the condition of the lock. This approach might save you from having to replace the lock altogether.
