How to build a a kitchenette?
Marinerescuelea
small budget, 2000mm long with a set of drawers for cutlery a under bench space for two bar fridges, functional bench top
what do you recommend also I need a L shape bench seat made 2000m x 1200mm with storage are these easy to or make by myself ?
Re: Marine Rescue Base needs a kitchenette
Hello @Marinerescuelea
Welcome to the Bunnings Workshop community. It's sensational to have you join us, and thanks for sharing your question about your kitchenette.
I propose using the following cabinets for your kitchenette:
The benchtop is the Specrite 2200 x 600 x 26mm Timber Multi Use Pine Panel and the sink is the Estilo Stainless Steel Single Bowl Square Sink. The bar fridge is based on the Mistral 85L Free Standing Bar Fridge. Please note that I did not include the wall cabinets and the microwave cabinet as these are not included in your request.
In regards to the "L" shaped seat with storage can you please provide us a little bit more detail regarding what kind of storage you're after and do you need cabinets under the seat? Does it need to be a seat where you can lift the cover to access items? Is it going to be fixed to a wall or do you want it movable? Any extra information you can provide regarding the build would be very much appreciated.
I've placed a sample image of what it can look like, if you wish to re-arrange the layout, please let me know.
That is great, we have a costing ? also can we have a sink with a drain rack & tapware, not a timber bench - due to water damage etc... any stone look industrial use .
Hi @Marinerescuelea,
Replacing the sink for one with a side drain, adding tapware and having a stone-look benchtop would cost around $1100 for the kitchenette. That doesn't include the upper cabinetry.
If you take the render Eric has prepared into your nearest Bunnings store, our helpful kitchen experts can assist with a formal quote.
Eric,
This is great, as per your picture which is perfect, can you included the cupboards and microwave shelf and we dont need the ends wall etc... but include sink with a drain rack and flick master style tap are skirting kick boards included ?. are these available as I need to do by Feb 15th
EricL has put together a fantastic rendering for inspiration, and it’s great to see that it aligns with your vision. If you’re looking to finalise your plans and obtain a quote, I recommend visiting your nearest Bunnings store to speak with one of our kitchen design experts. They’ll help you incorporate the details you’ve requested, such as including a microwave shelf, a sink with a drain rack, a flick mixer-style tap and the type of benchtop you require.
To get the ball rolling, it’s essential to finalise your choices from our range. Since there are many styles of sinks, mixer taps, and benchtops, you'll need to specify which type you'd like. The kitchen design expert will then put together a detailed quote, check product availability, and place your order. Since this project has a specific timeline, I’d suggest spending time with them as soon as possible to ensure everything is tailored to your requirements and ready by your deadline.
Remember to take this inspiration image with you so the kitchen design expert has something to work with.
