We're currently building a new home and wanted to add an arched look to our bar nook, but didn't want to spend a lot to get it done professionally, so we headed to Bunnings to see if we could attempt to do it ourselves, and we're so proud of how it turned out
Steps
Step 1
1/7Firstly, we installed the floating shelving, which fit our space almost perfectly.
Step 2
2/7We then measured out the arch that would fit the space best, traced it out on the plywood and cut it out using a jigsaw.
Step 3
3/7Once the arch was cut into the plywood, we used two off cuts of timber, cut them the same depth as the shelves and attached them into either side of the brick wall with screws.
Step 4
4/7We then attached the arched plywood to the front of the timber off cuts with screws, and used liquid nails to attach the bottom bits over the front of the shelves, which helped cover the slight gaps either side of the shelves.
Step 5
5/7Once attached, I filled all the nail holes with wood filler, and the gaps around the sides and top with No More Gaps.
Step 6
6/7Once it was all dry, I used a mouse sander to sand down the wood filler, the plywood and the shelves.
Step 7
7/7Lastly, I did one coat of primer on the plywood and shelves, and two to three coats of Dulux interior paint in the colour Vivid White to match our walls.
Re: Arched bar nook
Welcome to the Bunnings Workshop community @JoMarie-BB. It's marvellous to have you join us, and many thanks for sharing your terrific project.
Congratulations on your DIY arched bar nook! I'm impressed that you managed to find a budget-friendly solution and even more so that you've managed to create an impeccable semi-circle. I've recently been cutting some circles in timber, and I've got to admit it's not as easy as it looks. The nook's really giving me some Mediterranean vibes and I love it!
I'm curious to know, now that you've successfully created this beautiful arched nook, what are your plans for further DIY projects to add your personal touch to your space?
Wonderful work!
Subject | Author | Posted | |
March 2024 | |||
November 2023 | |||
September 2023 | |||
March 2024 | |||
November 2022 |
