What hose connector for a pressure washer?
anuppandey115
Hi all
Can you recommend what type of hose connector to use in this tap?
I just moved to a new property and was planning to connect to my pressure washer but seems like need some type of connector..
Live far away from bunnings so don't want to get it wrong..
Re: hose connector
Hello @anuppandey115
Thanks for sharing your question about finding a hose connector for your garden tap. Before going to the store, I suggest having a look at your hose attachments and see if you can find an item that looks like a GARDENA 13mm Universal Tap Nut Adaptor. If you don't find this piece attached to your garden hose, it will be necessary to get one so that you can attach it to the garden tap.
The GARDENA Tap Adaptor has a primary attachment that you can remove should you have a larger garden tap outlet. This means that you only need to purchase one type of adaptor for your garden tap.
Noyade
Re: hose connector
Morning @anuppandey115 and @EricL
An anti-back flow protector?
I believe Eric's Gardena tap nut adaptor is certainly a/the solution.
Can the protector be removed - or is it a council regulation?
https://sunshoweronline.com.au/brass-vacuum-breaking-check-valves-1/?ref=121094&gclid=Cj0KCQjwrfymBh...
