Watering system suggestions wanted
nagumuthu
Making a Splash
Hello Members,
Looking for a watering system to water plants and Trees on scheduled basis. [e.g. every morning / evening for certain time duration]. The layout and dimensions are pictorially represented in below figure. Could you please share of any watering systems for the purpose.
MM
Re: Watering system suggestions wanted
Hi @nagumuthu,
Can you please add where your water source is to the diagram? That will help our members greatly when suggesting the best options.
Have you had a look at @Adam_W's helpful article on How to install a drip irrigation watering system? If not, that would be a great place to start.
Some guides which you'll find helpful:
It looks like we'll be able to solve your irrigation needs relatively easily, and I look forward to providing some suggestions. If you can update us with that tap location, we can get to work.
Adam_W
Workshop Legend
Hi @nagumuthu Thanks for that diagram, makes it much easier :smile:
The water demands of veggies and trees are very different so I'd be looking a 2-zone system, these type of controllers are easy enough to find an set-up.
Chances are the trees will only really need water during establishment or very dry times a couple of times a week.
