Self watering Milano planters feedback
milliepoobah
why don't Milano put full instructions on their planter pots? I just lost a jasmine cos it got waterlogged. Didnt know about the plug under the pot till I saw your video. So thank you, Bunnings.
Re: Self watering Milano planters
Welcome to the Bunnings Workshop community @milliepoobah.
Thank you for your feedback, and I’m so sorry to hear about your Jasmine. I’ll pass your comments along to the team at respect, the manufacturer, to highlight the importance of including clear and complete instructions on their planter pots.
I’ll also reach out to you via private message to gather more details about your purchase. I trust our team would like to assist further, including replacing your Jasmine.
Thank you again for bringing this to our attention.
I bought the jasmine from Bunnings Mornington Victoria a few weeks ago.
Also need to know when to water these self-watering planters. I see the hole underneath for drainage.
I forgot to put water in the planter before adding the plant and soil!!!
All a wee bit complicated!
Pat aka milliepoobah
Hi @milliepoobah,
Apologies for the delay in response.
I will get in touch with the leadership team at Bunnings Mornington so we can arrange a replacement jasmine for you.
It's impossible to see it now that it is filled with soil, but at the base of the pot, there is a reservoir with a cylinder in the centre that sticks up about 5cm from the bottom of the pot. This cylinder is connected to the drain at the bottom of the.
The idea is that you can water the plant as you normally would from the top of the pot and the reservoir at the bottom of the pot will fill with water so that water is available for the plant to "self-water".
When the plug on the base is removed, once the water level gets higher than this cylinder the excess water will drain so you can't overwater your plant.
Please bear with me while I contact Bunnings Mornington. I will be back in touch.
Hi @milliepoobah,
Just reaching out to follow up on my email to you about using our Perfect Plant Promise to replace your Jasmine plant.
Have you had a chance to do this?
Do you require any further assistance with this?
