How to replace blade for Cheetah lawnmower?
GingerNinja
Cultivating a Following
Hi everyone. I have a Cheetah Lawnmower. It's not great but it does the job and starts first time every time which is great..  https://www.bunnings.com.au/cheetah-16-127cc-cut-and-catch-lawn-mower_p3381027
2 questions.
1. I need new blades as they are chipped pretty bad after a few years. Any thoughts on the best replacement that will actually be sharp and cut rather than thrash grass :smile:
2. Is there any companies that make larger/hard grass catchers for these. It fills so fast I empty like 6/7 times in summer during a cut
I have a 2 year old with a disability so time is short, so need mowing to be as fast as possible.
Re: How to replace blade for Cheetah lawnmower?
Hello @GingerNinja
Thanks for sharing your question about your Cheetah lawn mower. Please allow us to contact our supplier to get more information regarding the mower blade and catcher. As soon as we have more information, we'll get back to you.
Thank you for your patience.
Hi @GingerNinja,
The replacement blades for this unit can be ordered through your local store's Special Orders desk. The reference code for the bar blade kit is CA09582A. When blades become dull they either need to be replaced or sharpened. These replacement blades, although budget-friendly, are made by Briggs and Stratton and are of good quality.
The catcher assembly which is hard top and material bottom (no hard catcher (top and bottom) available) product code is CH87726A. It's slightly larger than the original material catcher, but since this mower is a 16" it can only accept catchers of that size.
GingerNinja
Thank you
GingerNinja
Are there any "in stock" blades that will suit. Or does it have to be that particular one
Ben
That's the blade that was specified to me as the replacement from the manufacturer @GingerNinja. However, you could take the blade into your closest store and the Power Gardening team member will be able to check other brands to see if there is an equivalent.
