How to remove sticky residue on plants?
Qldgarden
This sticky white 'stuff' is on some plants but the worst is on  the hibiscus. Three hibiscus get full sun and two others are in shade in the afternoon, but still get the heat.  The worst affected is in the full sun.  I have tried spraying white oil, rose spray, neem spray and the mixture of water and hydrogen peroxide.  The more I spray the more this 'stuff' seems to multiply.  Also hosing it off, which is great, but it evenutally comes back
Re: How to remove sticky residue on plants?
Hi @Qldgarden,
It looks like you have a mealybug infestation. Mealybugs can be persistent pests, but they are manageable with the right approach and some persistence of your own.
It's best to start by manually removing as many of the mealybugs as you can see and disposing of them. Use a bucket of soapy water and a washcloth to physically remove the scale and as many of the mealybugs as possible.
You can then apply Seasol EarthCare White Oil Insect Spray to the leaves of the affected plants ensuring you get good coverage. Make sure you don't apply this product when the temperature exceeds 32° celsius as it can cause leaf burn.
Manually remove any mealybugs that return and reapply white oil weekly as necessary.
With some persistence, you will get results.
Thanks JacobZ  I have that exact white oil spray.  Sounds like I have a big job ahead of me.  I will give that a try.
Hello @Qldgarden
My best advice is to make sure to spray under the leaves and branches of the plant as well. This is to make sure you get full coverage and there is nowhere for the bugs to hide.
