Hello,
I recently planted this ivory curl tree. It had been relocated from another person's garden. I didn't plant it straight away and I think the whole process might of dehydrated and shocked it a bit. Anyway, the trunk is still green when I scratch it so I assume it's still alive. The branches all snap quite easily.
Should I prune it close to where the branch meets the trunk? And will it be ok to do now?
Hello @Mj411
Thanks for sharing your question about your ivory curl tree. It sounds like your ivory curl tree is still alive, but it's likely suffering from transplant shock and dehydration. The fact that the trunk is still green when scratched is a positive sign, meaning the tree has a chance to recover. However, if the branches snap easily, they are most likely dead and should be pruned.
Now is a good time to prune, as this will help the tree focus its energy on new growth. Use Fiskars Bypass Pruners, available at Bunnings, to remove dead branches. Make clean cuts close to the trunk or a healthy junction, but avoid cutting too far into the trunk itself. If a branch still has some green or flexibility, prune just above a healthy bud rather than removing it entirely.
To help your tree recover, apply Seasol 1.2L Super Soil Wetter & Conditioner, which is excellent for reducing transplant shock and encouraging strong root development. For ongoing nutrition, use Osmocote 2kg Native Controlled Release Fertiliser, which is formulated for Australian natives and will provide essential nutrients over time.
Since the tree has been through significant stress, keeping the soil moist but well-drained is essential. Adding a layer of Ki-Carma 50L Cypress Mulch will help retain moisture and improve soil health. With consistent care, your tree should start to recover, but if you notice further dieback, you may need to prune a little more in a few months.
