How to remove sticky residue on plants?
Qldgarden
This sticky white 'stuff' is on some plants but the worst is on  the hibiscus. Three hibiscus get full sun and two others are in shade in the afternoon, but still get the heat.  The worst affected is in the full sun.  I have tried spraying white oil, rose spray, neem spray and the mixture of water and hydrogen peroxide.  The more I spray the more this 'stuff' seems to multiply.  Also hosing it off, which is great, but it evenutally comes back
Re: How to remove sticky residue on plants?
Hi @Qldgarden,
It looks like you have a mealybug infestation. Mealybugs can be persistent pests, but they are manageable with the right approach and some persistence of your own.
It's best to start by manually removing as many of the mealybugs as you can see and disposing of them. Use a bucket of soapy water and a washcloth to physically remove the scale and as many of the mealybugs as possible.
You can then apply Seasol EarthCare White Oil Insect Spray to the leaves of the affected plants ensuring you get good coverage. Make sure you don't apply this product when the temperature exceeds 32° celsius as it can cause leaf burn.
Manually remove any mealybugs that return and reapply white oil weekly as necessary.
With some persistence, you will get results.
Qldgarden
Thanks JacobZ  I have that exact white oil spray.  Sounds like I have a big job ahead of me.  I will give that a try.
Hello @Qldgarden
My best advice is to make sure to spray under the leaves and branches of the plant as well. This is to make sure you get full coverage and there is nowhere for the bugs to hide.
Qldgarden
Thanks EricL.....I am already doing that.  Fighting a losing battle here.  I have also read where some people have used vinegar with some success, so I am going to try that as well.  With the temps being off the scale in Brisbane at the moment, I have to wait until late afternoon to do any spraying or dealing with this ghastly infestation.
Hi @Qldgarden,
The vinegar mix is certainly worth a shot.
Give it a try and let us know how you go.
Qldgarden
I cut one hibiscus down to ground level yesterday.  I have done this before.  The mealybug infestation is far too advanced.  I will work on the new growth.
Hi @Qldgarden,
I'm sorry to hear it has come to this, but if the infestation is as awful as it seems, it may be the only way.
I'm sure your hibiscuses will bounce back in time.
Qldgarden
I think you would drive yourself nuts trying to get rid of the stuff.
I have tried the vinegar mix. (I made it a bit too strong and some leaves were burnt, but that sort of seemed to work)
Hydrogen peroxide mix (which has proved the best so far)
I am going to try the baby oil (2 tabs) fill spray bottle with water and a squirt of dishwashing liquid.  See how that goes.
I must admit the best advice I read online was you will never get rid of mealy bugs.  Even if you are super attached to plants, bin the infected plant (plants)  I know that is hard when some have moved on to established frangipani's, not in great amounts, which makes it easier to control.
I'll see how I go with the baby oil mix
Qldgarden
Just back to update.
I have since binned any infected potted plants that I had been working on to no avail.  One badly infected hibiscus has been dug out and there are two more in the firing line.  Too many mealy bugs.  To the point  where my gardening enthusiasm was low.  Now they have gone I am feeling a little better and will be keeping up controlling where I can.  I am at the moment using the baby oil mix so maybe I will let you know how successful that is in the long run.
