How to level lawn and sewage inspection point?
vic_w
Hi All,
My lawn is uneven. There is a significant dent in a particular section (4mx5m - 110mm deep from concrete- see pic). In this area, there is a sewage inspection point, which is also sunken over time - it has a concrete cover around it.
Any advice on approach to levelling the lawn ( and the inspection point casing) so it’s flush with the concrete slab? I would really appreciate any advice.
thank you
Re: How to level lawn and sewage inspection point?
Hello @vic_w
In this particular instance I suggest engaging the services of a registered plumber. Inspection junctions such as these can only be officially modified by professionals. You can also ask the plumber if it is possible to put the inspection point in a recessed container with a cover so that yo won't have to worry about running over it.
Please make sure to keep a copy of your docket so that should you get asked by your local council you can tell them that you had it professionally altered.
