How to fix watering hose line connection?
SaadMalik
Building a Reputation
Hello All,
I have got the water mist line that runs to the front garden at my house. However I  have got problem at the connection point between the tap and the mist line.
The water tap seems to release water not through the nozzle. Its got holes in the adaptor where the water comes out from.
Because of this when i turn on the tap, the water gushes out a lot. I have attached the photos for reference.
Can the adaptor be replaced or will i have to replace the whole tap for this? If yes then what tool will i need to replace the adaptor? I am pretty sure that there is nothing wrong with the mist line connection its just the adaptor that needs replacement.
Thanks,
Saad
Re: How to fix watering hose line connection?
Hi @SaadMalik,
It appears that you have an integrated vacuum breaker on your tap that has either failed or you are missing the flat rubber washer that should be present in the connector for your two-way adaptor. First, remove the two-way adaptor and check to see if there is a washer in the top of it. If not, you'll need to install a replacement washer. If there is a washer present, then it's likely that the vacuum breaker has failed, and you should try to unscrew it from the tap with a pipe wrench or multigrip pliers.
If you have trouble removing the vacuum breaker, the easier option might be to replace the tap.
