How to fix flat soaker hose leakage?
pc007
I don’t have sprinklers installed and it’s quite expensive to get them installed. Currently I am using soaker hoses to water my lawn and it’s going great. I move them when I need to mow and then lay it flat again on the ground.
Now recently I saw a leak in it. Is it possible some how to fix it rather buying a new one everytime.
Soaker Hose is similar to this one:
https://www.bunnings.com.au/pope-15m-soaker-hose_p3123318
Re: How to fix flat soaker hose leakage?
Hi @pc007,
You could try cutting the split section out and then using a 13mm polypipe barb to rejoin it. You'll also need a couple of 13mm clips
It would be best to verify the exact soaker hose you have with a team member in-store and to check whether using the barbed joiner to repair it would be suitable.
Also, remember that the Pope soaker hose has a two year warranty, so if they are failing within that time frame we'll happily swap them over for you.
