Hi, my sprinkler was working one day and not the next. How to put it right again please
Welcome to the Bunnings Workshop community @annmarie7. It's wonderful to have you join us, and many thanks for your question about sprinklers.
A few things you can check include making sure the tap is turned on enough to provide the required pressure for the sprinkler to oscillate. Also, check for any kinks in the hose that might be restricting water flow. It’s worth having a quick look at the mechanism to see if there’s any debris that could be preventing movement. Also, ensure no one has touched or bumped the oscillation limiting tabs into the wrong position.
If none of these solves the issue, the Gardena Aquazoom M comes with a five-year replacement warranty. If your unit is still under warranty, I’d recommend taking it back to your local Bunnings with your proof of purchase, and they should be able to swap it over for you.
Hi Mitchell, thank you for your detailed response. While Bunnings have replaced it, I can be mindful of these possibilities for future reference. I do feel Gardena should supply some kind of troubleshooting explanation in the package. I’m unsure what a wrong position with the tabs would look like. Thanks once again. Service I can trust.
Hi @annmarie7,
I'm glad to hear we replaced the unit.
The tabs I'm referring to are the governors for the oscillation angle, which are circled below. They are likely explained in the manual. If the two tabs are pressed together, the oscillation will stop, as that means you want 0 degrees of travel. They represent the angle at which you want the unit to spray back and forth.
