Hi All, I am undertaking a small pram repair (handle) and would like to know what tool is required for opening screw as per phot. Have tried a hex key and does not work - it seems to have finer grooves and different sizing.
Pram is a Britax / Steelcraft model.
Thanks and regards, Ashoo
Hi @ranjitha
The photo is very blurry sorry it looks like a torx screw
I would highly recommend buying a set of Screw drive multi tip speciality kit for cordless drills
It has all the common driver options you will use occationally. You have life time off these little jobs ahead of you its worth the extra $ to plan ahead.
https://www.bunnings.com.au/ryobi-40-piece-specialty-metric-drill-and-drive-set_p0354519
A great starter package you will use for years to come.
I/N: 0195859 $99
Thanks for the feedback - much appreciated. Have purchased the Ozito set and will now buy the Torx screw attachment bits.
Hi @ranjitha
Remember get the Multi bit set Multi Bit set as the photo is blurry .
If it isnt torx screw the set will have other options to undo the screws thats the magic of that set.
Hi @ranjitha,
A warm welcome to the Bunnings Workshop community.
@Jewelleryrescue's advice should get you through.
If you have any issues, please don't hesitate to reach out.
