Ozito cordless battery compatibility
Ricochet
Hi.   I have just bought an Ozito 12v cordless drill.  Could I use the battery from that in an Ozito 18v Circular saw or other Ozito power tool.
sun
Ozito PXC 18V Grass Trimmer Kit
Ozito PXC 18V Grass Trimmer Kit with 2ah battery
Instead of 2ah battery can I use 4ah battery ?
Re: Ozito PXC 18V Grass Trimmer Kit
Welcome to the Bunnings Workshop community @sun. It's wonderful to have you join us, and many thanks for your question about the Ozito cordless grass trimmer.
You'll be pleased to know that this unit accepts all Power X-change batteries. So if you have a Power X-change branded 4ah battery, it will work on this machine.
We look all about your projects and plans around the house and garden. Please reach out anytime you need assistance or have something to share.
Please let us know if you have more questions or need further assistance.
david6
Metabo radio compatible with Ozito battery?
Hi team member
                          I have recently brought a Metabo digatil workplace radio and wass just wondering if you can advise me on .weather an ozito 18 v battery is compatable with it  thank you
Re: Metabo radios
Hello @david6
Welcome to the Bunnings Workshop community. It's magnificent to have you join us, and thank you for sharing your question about your Metabo radio.
One of the best things that Metabo did with their battery design is that they've kept its form factor, which means that a new battery will still work with an old Metabo tool. However, the Ozito battery and the Metabo battery may look similar, but that's as far as it goes. I don't recommend testing an Ozito battery into the Metabo radio for the fact that the polarity and functionality of the pins are differently laid out.
Forcing the Ozito battery into the Metabo radio slot could result in either the radio being damaged or the battery shorting out. A good investment option would be to consider getting a Metabo 18V 1 Piece Cordless Brushless Combo Kit. When you consider that if you were to purchase these items individually, it would cost a great deal more. Whereas in this kit form you get two batteries and the charger plus the drill included.
ozito
can i used my 18 volt ozito drill battery on my 18 volt ozito mower
Re: can i used my 18 volt ozito drill battery on my 18 volt ozito mower
Welcome to the Bunnings Workshop community @ozito. It's brilliant to have you join us, and many thanks for your question about battery compatibility.
The battery will be compatible if the drill and mower are both from the PXC series. If you can show us some images of the drill, mower and battery, our knowledgeable members will be able to confirm whether the battery is interchangable.
tando82
ozito batteries
Just wondering if the ozito pxc batteries will fit into other ozito tools ie: whipper snipper. I have the base model and find that the battery dies pretty quick and am looking for a upgrade.
Re: ozito batteries
Welcome to the Bunnings Workshop community @tando82. It's great to have you join us, and many thanks for your question about Ozito battery compatibility.
All PXC series batteries will work will all PXC series tools. If your whipper snipper is a PXC version, then the PXC batteries will work in it. If you have the Ozito 18V Cordless Grass Trimmer Kit or similar base model, I'd recommend you speak with the Special Orders team at your nearest Bunnings to order a suitable additional battery or consider upgrading to a PXC series line trimmer. Once you've purchased a tool and battery in the PXC series, you'll know everything else in that series is compatible.
wwoman68
ozitu battery
Can you also use the ozitu battery for the blower/ edger combo and vice versa in the ozitu lawnmower?? thanks
Re: ozitu battery
Welcome to the Bunnings Workshop community @wwoman68. It's brilliant to have you join us, and many thanks for your question about Ozito battery compatibility.
The battery will be compatible if the blower/edger combo kit and mower are both from the PXC series. If you can show us some images of the blower/edger, mower and battery, our knowledgeable members will be able to confirm whether the battery is interchangeable.
They're compatible if it's this combo and one of these mowers.
