Googling this morning I found this on the Bunnings website.
I've just returned from Bunnings.
I was told it was "a promotion that is no longer available."
How can you tell - when you look at the site?
Cheers.
Hi @Noyade,
When you have added your local store to the website it will give an indication of stock level there. If it comes back as "Low stock", I recommend contacting the store to check availability before heading in. I note when Wagga Wagga is selected, it comes back as "Out of stock", and I apologise for the inconvenience. You might like to speak with a Special Orders team member to see if they could order one in for you, but that's not always possible with promotional items.
If you already have other batteries, then the Ozito PXC 18V 125MM Brushless Angle Grinder Skin Only PXBVAGS-125 skin is in stock. Similar price, but you don't get the battery and charger as it's the brushless version.
I've just double-checked with the store @Noyade, and they do have the Ozito PXC 18V 125MM Brushless Angle Grinder Skin Only PXBVAGS-125. There's currently 15 units on the shelf.
Yeah, I saw those mate - but skin only.
No, I have none of the batteries.
The promo was a much better deal! 😁
To clarify, the deal is a brushed angle grinder, and the skin is the brushless version @Noyade. So, if you only need the brushed version, it's a better deal. The brushed skin would likely go for around $89.
Ok, sorry, they're all looking similar now.
So, how much is a battery and charger for the $119 brushless skin?
For the same battery and charger that is in that kit it would be the Ozito PXC 18V 4.0Ah Battery And Charger Pack for $99, @Noyade.
Going for the brushless skin would be a reasonable choice if you already had the battery and charger.
