How to replace tyres on an old furniture trolley?
gnicholson
Building a Reputation
We have borrowed this trolley to help us shift furniture to the garage as house is being styled for market next month.
One of the wheels is continually flat and goes down even when pumped up. I went to Bunnings last week and bought a new wheel. However, it is smaller, maybe they no longer make the same size. What is the difference between offset and pnuematic? The size is 27cm diameter of the old one, measured from one side of the tyre to the other. Could both wheels fit and work if smaller and is this a job we can do ourselves? Do you know anyone who would fix it if we can't?
Cheersold tyreold tyretrolley 1.jpgWould this fit? 254 mm is what the diameter?Would this fit? 254 mm is what the diameter?I bought this one as cheaper 250 mmI bought this one as cheaper 250 mmWould this fit?  $30.50Would this fit? $30.50
Noyade
Home Improvement Guru
Re: Replacing tyres on an old furniture trolley
"They're 10" wheels.
Outside tyre diameter is around 290mm
Axle is 19mm diameter.
Those Sherlock wheels would fit?"
I'm wondering if my cracked tyres are contributing to the overall 290mm outer tyre diameter?
The Sherlock would be a very close replacement then?
https://www.bunnings.com.au/sherlock-medium-trolley-wheel-assembly_p3360570
I don't believe they will @Noyade. How wide is it across the steel wheel section? Those Sherlock are only four inch.
At 290mm, those would be considered very large trolley wheels. They're more similar to a small wheelbarrow wheel. Are there a series of numbers on the tyre we can reference?
Noyade
Thanks for looking into this @MitchellMc
Pretty sure a 10" wheel.
I'll recheck and get back to you.
Cheers!
Noyade
Rough estimate is they would be around 40 years old.
Hand made welded trolley by my father.
The locking ring grub screw - is most definitely imperial  - 1/8" hex.
See what ya think mate.
Cheers!
Fissures appearing...Fissures appearing...
