How to replace latch on plastic case?
Noyade
Just now - 204 sockets ended on the floor.
Plastic blow-molded case latch fatigued off.
Poor design.
Tried to plastic weld it back but failed miserably.
It's tough plastic - I believe it can be pop riveted. Anything in Bunning's armory might suit/fit?
Cheers.
How it should lookHow it should look
The other side...The other side...
Possibilities, or something similar?
Re: Looking for Latch Ideas for Plastic Case.
Hi @Noyade
I suggest having a look at these catch plates and see which one fits your tool case:
Please double check your measurements or bring the empty cool case to the store to make sure the catch plate fits the front profile.
Noyade
Thanks very much for that @EricL
The one you have illustrated looks great.
I'll have a look this weekend - and update you.
Cheers.
R4addZ
Building a Reputation
Re: How to replace latch on plastic case?
Hi @Noyade
When the latch on mine did the same, I just bought a length of velcro that went right round the case!
Noyade
G'day @R4addZ !
Yes - I considered that! 😁
It weighs 15 kg - too heavy for just the plastic strips the case came with and fatigue is setting in
I'd like to see your case - maybe we can improve on the velcro?
Noyade
I bought a latch today - as rain is predicted for the weekend. The Goliath selection was rather diminished - only your illustrated latch was available @EricL
Here's the problem again...
Noyade
Best fit as I could determine was with the main body on the lower side - but that plastic ridge was interfering with the fit.
So with a little 300 watt hot-air blower I was able to heat the plastic and push that ridge down...
Noyade
Next I positioned the latch - but I found with drilling up front - the drill tip tended to skip and slide, despite being just plastic.
So I punched holes with a very sharp scribe, then drilled....and pop-riveted.
Noyade
Works 100% better than the original.
But for symmetry - do the other side? Or is that tempting fate - just wait for them to break?
Thanks again for the hardware tip @EricL  - one of many things that makes this site great.
Cheers.
